Författare [EN] [PL] [ES] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] Ämne: BMW 130i goes really bad...  (läst 3059 gånger)
Utloggad theone1973
  • Antal inlägg: 3
« skrivet: april 13, 2016, 13:10:32 »
Hi,
I hope someone can help me !
My 130i -06 started going bad the other day. Went on 5 cylinders and vibrate.. Error code by in Inpa 29D2 and 2E1D . Replacing all the ignition coils and the sparks ( BMW OE ) I was sure that the error was one of those . I still get misfire in cylinder 6. Change the injector on cylinder 6....still the same fault..
I don't know what to do...hope anyone have some idea !
BMW 130i (N52) 265 hp , 160000 km.
« Svar #1 skrivet: april 13, 2016, 13:36:34 »
Have you configured the new injector?
« Svar #2 skrivet: april 13, 2016, 13:53:03 »
Hello and welcome to Bimmerpower.org. ;)
It goes bad in the engine?
29D2 -
Misfire, cylinder 6
Typically caused by worn out spark plugs, failing coil packs, intake valve build up, or failing injectors. Replace as needed.
2E1D
ignition, cylinder 6
you can watch here, maybe it can help you
You can change the language on top of the text.
Utloggad theone1973
  • Antal inlägg: 3
« Svar #3 skrivet: april 13, 2016, 14:03:57 »
the new Injector doesn't have to be coded, my engine is the first of all..my car is in a workshop and they also say that I don't need to calibrate the Injector. now they will change the Injectors between cylinders and see if the problem goes to another cylinder.
Sparks and coils is new , I was sure the problem was here...
Is the N52 engine "bullet proof" ? The engine cant be broken rigtht ?
« Svar #4 skrivet: april 13, 2016, 14:08:04 »
Sorry i was thinking of the N54 engine.
Utloggad theone1973
  • Antal inlägg: 3
« Svar #5 skrivet: april 13, 2016, 16:22:22 »
Cylinder 6 = 0 compression , cylinder 3 also very low. Engine is broken in a way....so sad !!
