Författare [EN] [PL] [ES] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] Ämne: 39 km på 43 år.  (läst 2775 gånger)
Utloggad Leif L
  • Antal inlägg: 538
    • www.e28klassiker.se
39 km på 43 år.
« skrivet: februari 08, 2012, 14:37:17 »
Jösses....häpnadsväckande att man inte kört mer med den på dessa år......det vattnas i .....;)  Vad stod priset på denna modell 1969 ? En fin pension på ålderns höst ;)
http://www.blocket.se/helsingborg/1969_BMW_2800_00039km_fabriksny_bil_38536284.htm?ca=3&w=3
1969 BMW 2800 00039km fabriksny bil
Pris 355 000:-    Modellår: 60-tal   Växellåda: Manuell   Plats: Helsingborg
Miltal: 0 -499    Tillverkningsår:-      Bränsle: Bensin.
This beautiful BMW 2800 has been stored in a private collection in Germany since the day it was delivered from BMW, and has never been registered. Having covered only 39km, and with full documentation, makes this car very rare and collectible. 1969 was one of the very first years of the E3 model, and it differs from the later and more common Series 2, with its aluminum front grilles, different tail lights, horizontal C-pillar vents, trim etc. The cosmetic and mechanical condition is fantastic, and the car is still NEW in every way. A restored car will never reach this level of originality. The car is finished in single stage Tundra green metallic and beige corduroy. The mechanical parts of the car have been preserved as well as cosmetically. The car has been started regularly, moved around to keep fresh gas in the tank and carbs, and to lubricate all moving parts. All rubber around windows, engine compartment, trunk, tires etc is still soft and has not creeped the slightest bit. Bare metal parts such as exhaust manifolds, on the engine block, and brake discs are not even surface rusted! The engine, gearbox, rear diff, brake calipers, etc. are all in order, with no leaks or the slightest sweating. There has been no cleaning done to make anything look dry. Just as the rubber seals in the doors, trunk and engine compartment, the oil seals are in great shape. Fluids have been drained and replaced regularly to avoid absorption of humidity.
Mit Svenske er ikke så godt, bilen findes 40km fra Helsingør. HT båd kan indgå i handlen. Mvh
Mejla eller ring Michael Stegmann, +4529804165
39 km på 43 år.
« Svar #1 skrivet: februari 08, 2012, 14:58:30 »
Oj! Vilken skönhet!
39 km på 43 år.
« Svar #2 skrivet: februari 08, 2012, 15:51:07 »
En riktig Oldtimmer, vacker syn!  8)
Utloggad The Snowman
39 km på 43 år.
« Svar #3 skrivet: februari 08, 2012, 16:32:04 »
Wow!  ;D
Glider: BMW 2000, 1969
39 km på 43 år.
« Svar #4 skrivet: februari 08, 2012, 17:47:23 »
En skönhet som man kan har i vardagsrum.
