BMW 545i E60 2005 Car Specifications
Release Date: 01/09/2004
Make: BMW
Variant: SPORT
Series: E60
Year: 2005
Body Typ: 4D SEDAN
Seats: 5
Engine Type: MULTI POINT F/INJ
Engine Size: 4.4L
Cylinders: V8
Max Torque: 450
Max Power: 245 KW
Bore & Stroke: 92x82.7
Compression Ratio: 10
Valve Gear: VARIABLE DOUBLE OVERHEAD CAM
Transmission: 6 SP AUTOMATIC STEPT
Drive Type:
Final Drive Ratio: 3.38
Fuel Type: PREMIUM UNLEADED PETROL
Fuel Tank Capacity: 70
Fuel Consumption (City): 15.8
Fuel Comsumption (Hwy): 7.7
Kerb Weight: 1635
Gross Vehicle Weight: 2195
Height: 1468 mm
Length: 4841 mm
Ground Clearance: 148 mm
Toing Capacity: brake(2000), Unbrake(750)
Steering Type: RACK & PINION - POWER ASSISTED
Turning Circle: 11.4
Front Rim Size:
Front Tyres: 245/40 R18
Rear Tyres: 245/40 R18
Wheel Base:
Front Track: 1558
Rear Track: 1582
Front Brakes: DISC - VENTILATED
Rear Brakes: DISC - VENTILATED
Front Suspension: MacPherson strut ; Lower control arm ; Gas damper ; Coil Spring ; Anti roll bar ; ;
Rear Suspension: Transverse link ; Coil Spring ; Gas damper ; Anti roll bar ; Trailing arm ; ;
Discontinued Date: 31/10/2005
Service Interval: 148
Warranty Months: 24
Warranty Kilometers: 999
VIN Plate Location: Driver Side Inner Guard
Country of Origin: GERMANY
