Författare [EN] [PL] [ES] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] Ämne: En bilsamlares våta dröm, två unika M3 E30.  (läst 2767 gånger)
Utloggad Helmut S.
  • Antal inlägg: 157
« skrivet: mars 18, 2010, 10:32:19 »
Underbart! Tänk er lyckan att som BMW-fantast hitta två st klenoder i detta makalösa skick:
Finns mer info här:
http://www.bmwblog.com/2010/03/17/best-barn-find-ever-2-brand-new-bmw-e30-m3s/#more-3150
SV: En bilsamlares våta dröm, två unika M3 E30.
« Svar #1 skrivet: mars 18, 2010, 12:12:13 »
Helt otroligt, att det dessutom är två M3 SE vad jag förstod gör inte saken sämre precis.
Lite om E30 M3 SE:
"What distinguishes an E30 M3 Sport Evolution?
The E30 M3 Sport Evolution, produced in late 1989 and early 1990, was the most extensively modified of the three E30 M3 Evolution editions. The cylinder bore was increased to 95mm (from 84mm) and a long-stroke crank was added to boost displacement to 2,467cc (from 2,305). In addition, the valves were enlarged and a more aggressive cam was fitted. Special nozzles sprayed oil under the pistons to keep them cool. All Sport Evolution motors were equipped with catalysts. The end result was a power increase to 238 hp at 7,000 rpm, though peak torque decreased slightly (over the Evolution II) to 177 lb/ft at 4,750 rpm. These engines use the regular black cam cover but have red spark plug wires. The gearbox remained unchanged but the 3.15:1 final drive was fitted.
Like the Evolution II, the Sport Evolution has thinner glass, a lighter trunk and bumpers, and brake cooling ducts in place of foglights. In addition, it also has a smaller fuel tank. For homologation purposes, the Sport Evolution has unique front and rear spoilers with adjustable extensions for greater downforce, even wider front fenders, and reprofiled grille slats with sealed gaps for better aerodynamics, all of which have negligible effect on the street. The M3 Sport Evolution also sits 10mm lower than the normal E30 M3.
The Sport Evolution was only offered only in Jet Black (668) with red bumper stripes or Brilliant Red (308) with black bumper stripes. The wheels are the same 7.5x16-inch cross-spoke items used on other Evolution models, but the spokes are painted a darker Nogaro Silver. Comfort items such as power windows, a sunroof, on-board computer and air conditioning were all deleted in order to keep weight down, though they could be ordered as options. Even the interior map lights and grab handles were deleted. Recaro sport seats with integrated headrests were standard in Anthracite M cloth. Black leather with the M tri-color logo was an option. A suede-covered M Technic II steering wheel, shift knob and parking brake handle were included along with red seatbelts. Door sill plates with color "M3" insignias were added and a special plaque denoting each car as a Sport Evolution appears on the center console (though it does not include the unique number of each example out of the 600)."
 http://www.bmwmregistry.com/model_faq.php?id=8
« Svar #2 skrivet: mars 18, 2010, 12:20:02 »
Säkert lyckligt M3 ägare!
Utloggad Helmut S.
  • Antal inlägg: 157
« Svar #3 skrivet: mars 26, 2010, 08:41:46 »
Jasså, de var av specialmodell. Extra skoj alltså. Är det den modellen som  har större hjulhus för att husera större fälgar/hjul på banorna när det begav sig?
