Författare [EN] [PL] [ES] [PT] [IT] [DE] [FR] [NL] [TR] [SR] [AR] [RU] Ämne: Problem med Safari och forumet  (läst 15473 gånger)
Utloggad MrB
  • Antal inlägg: 769
SV: Problem med Safari och forumet
« Svar #30 skrivet: januari 09, 2010, 21:57:29 »
Sedan är jag tillbaka om "maximum cache size too small" eller att tömma Temporary Internet Files, Cache eller cookies.
Hittade det här!
Citera
I may have resolved the issue, though I hesitate to declare victory too soon.
I noticed that my ~/Library/Cookies/Cookies.plist file was back to 2.5MB (its size before I deleted it). So I quit all running programs, deleted the file again, and restarted Safari.
So far so good. I believe that the Cookies.plist file is used by multiple applications, so maybe another one of those rewrote the original one.
Och det här
Citera
Thanks for sharing. I think I may have resolved it as well, though I took a different approach.
I...
1. Repaired Permissions with Disk Utility (there were 3 errors)
2. Reboot
3. Deleting cookies from Safari still didn't work so I Reset Safari instead from the File Menu.
4. Restart Safari, cookies gone.
Facebook and a few other apps appear to be behaving again... so far. I'll update again if I encounter further issues.
länk: http://discussions.apple.com/thread.jspa?threadID=1828211&start=0
Rebell Design !
Utloggad MrB
  • Antal inlägg: 769
« Svar #31 skrivet: januari 09, 2010, 22:05:45 »
Det vikiga verkar vara att stänga ner safati först.
Citera
if you do this while Safari is open, it will recreate the file when you quit.
Rebell Design !
« Svar #32 skrivet: januari 09, 2010, 23:46:06 »
Skumt fel det där, har tyvärr inget matnyttigt att komma med men det fungerar utmärkt för mig. OS 10.6.2 och Safari 4.0.4
Utloggad MrB
  • Antal inlägg: 769
« Svar #33 skrivet: januari 10, 2010, 15:25:33 »
Rebell Design !
« Svar #34 skrivet: januari 10, 2010, 15:41:33 »
Bra att postar info om problemet, MrB...!!
Utloggad Dekagon
  • Antal inlägg: 111
« Svar #35 skrivet: februari 27, 2010, 09:34:01 »
Det där felet med att sessionen gått ut har jag fått massor med gånger i IE8 under Windows7-miljön. När jag kör safari på min Mac fungerar det dock felfritt! Så för mig är snarare problemet det motsatta i såna fall haha  ;D
Jag tror det är server/forum-relaterat snarare än klient-relaterat ;-)
//Daniel, Systemutvecklare
« Svar #36 skrivet: maj 02, 2010, 14:36:44 »
Dr Tinnitus...har det hänt något med ditt Safariproblem?
Utloggad Dr Tinnitus
  • Antal inlägg: 125
« Svar #37 skrivet: maj 02, 2010, 14:48:19 »
Nä, samma problem
« Svar #38 skrivet: maj 02, 2010, 14:54:24 »
Har du prövat att regga dig på vårt testforum...
http://sverigeland.com/bmw/index.php
Det innehåller samma programvara som skall installeras här.
« Svar #39 skrivet: juni 25, 2010, 13:12:59 »
Nä, samma problem
Inget nytt om dina problem med Safari?
  • Antal inlägg: 125
« Svar #40 skrivet: juni 26, 2010, 20:05:18 »
Hejs.
Om du kikar i min tråd om min 740iL, där jag senast skrivit om EDC-fenomenet, så kan du se att det nu verkar funka fint att skriva direkt från Safari efter att forumet varit nere i en månad.
Dr Tinnius
  • Antal inlägg: 125
« Svar #41 skrivet: juni 26, 2010, 20:07:11 »
Funkade kalas denna gången med, ja i inlägget ovan Kilroy. Så det verkar som om det trots allt var nåt knas på "er" planhalva och inte min, för jag har inte ändrat ett jota här på något sedan sist jag försökte och det inte funkade.
Hur som helst är det ju bra att det verkar funka nu oavsett var eller vems problemet var.
Dr Tinnitus
« Svar #42 skrivet: juni 26, 2010, 22:45:38 »
Dr Tinnitus
Kanonbra att det funkar nu... ;D
