I may have resolved the issue, though I hesitate to declare victory too soon.I noticed that my ~/Library/Cookies/Cookies.plist file was back to 2.5MB (its size before I deleted it). So I quit all running programs, deleted the file again, and restarted Safari.So far so good. I believe that the Cookies.plist file is used by multiple applications, so maybe another one of those rewrote the original one.
Thanks for sharing. I think I may have resolved it as well, though I took a different approach. I...1. Repaired Permissions with Disk Utility (there were 3 errors)2. Reboot3. Deleting cookies from Safari still didn't work so I Reset Safari instead from the File Menu. 4. Restart Safari, cookies gone. Facebook and a few other apps appear to be behaving again... so far. I'll update again if I encounter further issues.
if you do this while Safari is open, it will recreate the file when you quit.
Nä, samma problem
Inget nytt om dina problem med Safari?
Funkade kalas denna gången med, ja i inlägget ovan Kilroy. Så det verkar som om det trots allt var nåt knas på "er" planhalva och inte min, för jag har inte ändrat ett jota här på något sedan sist jag försökte och det inte funkade. Hur som helst är det ju bra att det verkar funka nu oavsett var eller vems problemet var.Dr Tinnitus
